Silverbullet
Hi Guys the first Troopers are in the USA now.They will be at a few dealers in the next few weeks.This is the new trooper pictured.
Rick
Rick,
So this makes me wonder. Since there is no Joyner USA and you say they are in the states now...where are they? Wouldn't they have to come to the dealers directly? Why would it take a few weeks to get to your door? Sounds like a slow truck from China as well.
Paul
Quiq, would not come up on my computer either. Found the Trooper on Craigslist so here is another link, http://phoenix.craigslist.org/evl/rvs/2501289505.html
Looks like they used the same pics as No Limits pic, http://www.joyner-atv-utv.com/
The pics are canned pics.
rocmoc n AZ/Mexico
Sorry it didnt come up.
Rocmoc your right,thats kinda what i was refering to as well as price.Guess none are here yet so everyone is using promotion photos.
If this is the 2011 and is as it comes from the factory?
There is a couple of things I noticed. The lights have been moved down to the location I used 4 years ago. They have gone to expanded metal in the bed above the engine like I did last year. And they moved the spare tire location like I did 3 years ago. I feel like I am on the cutting edge. Maybe the 2012 will come out with a lower cage & 31X15 tires & supercharger, LOL!
rocmoc n AZ
    • By mark walkom
    • By Wolfpaak
      Pink Floyd quote/reference.
      i am looking for a starter for my 2004 800 Renegade and apparently the place I dealt with before is no longer in business. Any help?
      Thanks in advance,
      Kenny
    • By Hisun .500
      So my hisun 500 is tore up and all the wiring is wasted i was wondering can i pull out all the wiring and just put in the. Basics .please help
    • By Bennche x4
      Has anybody put portals on there bennche x4
    • By robwork9
      Hopefully someone out there is a T-Boss 410 electrics expert or a Massimo mechanic is viewing this. I parked my 410 and it was working great. I came back a week later and attempted to crank it and nothing. Turned the key and no power. Figured it was a bad/low battery so I charged it. Still nothing. Attempted to jump start it and still nothing. Usually when I put the key in and turn it to the first position, the display comes on and I hear the ECU and other items boot. Now it is doing nothing.
      I slowly went through the electrical system and found the main fuse attached to the starter relay, part 71602 (pic 1) blown. I figured replacing this fuse would fix my problem. It didn't. I then ordered a new starter relay thinking maybe that part had gone bad and caused the fuse to blow, but a new relay did not fix the problem.
      I have found a work around for starting the machine. If I take one of the purple/black leads (pic 2) and insert one of them in the bottom right of the starter relay (pic 1 and 3) then the machine will get power even with the key in the off position.  I'm bypassing something but don't know what. I can use my right hand to hold the wire against the lower right of the starter relay, reach over and hold the brake with my foot, then take my left hand and turn the key and it will crank. As soon as I remove the wire from the relay the machine shuts down. I have even removed the power distributor box and it will still get power when I touch the wire to the relay. Of course this is not the way it should work but if I can't solve this problem somehow I may just have to rig a connector to the relay and bypass whatever is causing the electrical issue. Massimo has told me the purple/black wires on my model are not used.
      Any help in figuring what my problem may be or other items I can try?
      v/r,
      Rw
