I don't think you would be considered t4, not long enough,not enough door openings.. "BUT" I would say you are "T2 +"" extended cab, just like in pu's. ;) ;) :rolleyes: :rolleyes:
  • 3 months later...
Sounds like you guys have it about right.
Very cool , I have been talking about doiny this since I bought my trooper. Actually I started on it last year but then put it in storage. I need a rear shock and then finish up the rear cage so the kids can ride
    • By Unhappy Kioti K9 Owner
    • By Bbicon
      I have a 2014 odes 800 dom. I  have a wire in the same harness as the fuel pump plug ( just before it ) and it is not connected to anything t has a connector and a little brass connector on the end , I was wondering if anyone could tell me where it goes to
    • By Xov
    • By Dennis
