Guest Lenny
How about the Rubicon trail. Always wanted to try ride it but really don't know anything about it. Always under the impression that it's challenging. Would it be over our heads?
I have done the Rubicon twice, once with a dirtbike (really tough) & once with a Jeep. The Trooper would handle it easily. The problem is the crowds, everyone wants to do the Rubicon. It is only accessable after and before the snow melts or starts to fall. It is just a short season. I did it 20 years ago and it was tough to find a window on the trail then. Most go from West to East and drive the main highways back home. We could not do that so you would be doing it in reverse against the tide & it would take more than a single day.
NOW, you can do short trips in and do only a small part of it. There are a couple lakes that we use to go to, camp and then drive out a few days later. Lots of big rocks. Timing is everything with regards to the trails condition.
Plus the Cally Greenies are all over you!
rocmoc n AZ
    • By Jacob E freeman
    • By Woody77
    • By diamondjfarm
      Thanks.
    • By Greg Kilgore
      We all know summer is hot inside the cabs of our SXS. So I've rigged up a couple of fans to help cool down the cab.
      I didn't want to drill the fan's "support rails" into the ROPS (Roll Over Protection System), aka roll bars. So I used water clamps to hold them in place.
      I just need to replace the wires I ran with bigger gauge. Then finish the wiring to switches, relays, and battery. But the hardest part. The actual mounting of the fans is complete. Also just in case anyone plans on doing this. I may have to only use 1 fan in the middle instead on 2. Due the the draw on the battery.
      The fans are 12", 12V 80W. So I'm figured they were 6.7 amps apiece. Used the WAVe formula to get unknown values Watts=Amps*Volts then solve for unknown. I know the watts and volts from sticker on fan. So just used above formula to get amps. So a 7 amp fuse should be OK and a 10 amp fuse will be good.
      So pulling 14 amps from the battery all day may be too much for the charging system to keep up with. And I haven't even installed the radio yet. So I will have to test and let you know.
      See pics below.
