Welcome. Most electrical problems on the Trooper start with moisture. Being in AZ, I am one of the few with the exception of the under-sized fan fuse.
Hang in there electrical bugs can drive you nuts !
rocmoc n AZ
    • By Wolfpaak
      Kenny
    • By Marie
    • By Paul L
