    • By Kingfish
    • By mac66
      Apparently, these are Hisun or at least they use Hisun engines. I can't find much info on them online yet.  Ran across a used one with just 100 miles on it as a very reasonable price.  Just curious.
    • By sxr951
      corrosion had its oring neck area  jammed in.. and besides that had corrosion in the starter just shorted when ran direct jumper cable to the starter post power to it
