Summer just closed!
AND it was the SECOND HOTTEST summer on record for Arizona. AZ has 150+ years of weather records. This is the first summer that we can't wait for it to cool. Never in 10 years have we ever wanted to see summer end but we do this year. It has been so hot and humid (at times), we have not had the Trooper out since the Jamboree. If it keeps this up we will have to move to a cooler location like UT or ID. On the bright side we got a tandem Kayak for this winter's trip around the Gulf of Mexico & Florida. If you have noticed we are not been adding /Mexico to our signature any longer. Just too unsafe currently to go to Mexico so have to go somewhere else in the winter. We have been using our/MY Senior Pass for the National Park Campgrounds, what a savings! There are a few good things about getting older, not many, LOL ! Who knows Senior Pass may go away with the upcoming budget cuts, so using it a much as we can now. Just babbling to generate active on the board. Are you all still ALIVE !
rocmoc n AZ
Summer just closed!
rocmoc n AZ
been warmer then usual here too.get a boat and get out on a lake..Thats why we like the place in Havasu,it can get up to 115-120 but get out on the lake and spend the day in and out of the water and you dont hardly notice it ;). you cant go away for to long this winter,we have to get together for some riding.
Won't be available until mid-Oct. Oct is always great weather in AZ.
rocmoc n AZ
Im game,get a date together and we will see if we can make it.Maybe half way somewhere.That would be a 6 hour drive for you and a 1/2 hour for me(LOL) seriously October sounds good.
    • By Jerrys500
      Thanks Jerr
      Picked up an essentially new 2022 UT400 with 9 miles on it.  Decided to change the oil because it's probably never been done.  Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out.  What should I start checking?
    • By mark walkom
