Labor Day Weekend!
By Kingfish
By mac66
By sxr951
By SafeSledBryan
Hey guys! My name is Bryan and i am the owner and creator of Safe Sled. Not some crazy corporate backed recovery product, but just some guy with an idea.
4 years ago, I suffered 11 strokes, and am now 50% paralyzed on the left side of my body. I am unable to work a normal job anymore. I was working on the sled 2 years before this all unraveled. My wife told me to keep working on it since i was pissing her off staying home and doing nothing.
I still plan on improving and implementing different ideas as the product’s revenue continues to grow.
if the sled is appealing to you, please check out my website, safesledoffroad.com
Safe Sled Website
