Desert Bash and Off Road Poker Run
By SteveS
By Michigan sport.
I'm sure many of you are aware of Michigan's emergency brake requirement. I'm wondering if anyone has a good solution.
Beyond paying the few fab places $$$$.. I'm curious is there another rear caliper with e brake style that would interchange with slight mods to the Maverick sport rear mounting bracket?
By Hugh
Cooling fans are working, I can hear it running once awhile if I can get the engine warm up enough. Thank you for all the help.
Hugh
