I have a 2006 Trans Mule, and a winch from Harbor Freight and the holes on the winch do not match up with the mounting holes on the Mule plate under the radiator? Are there certain winches or a universal mounting plate that will take any/all winches to mount onto a Mule ? Any ideas on where to get a plate that will help me mount the winch ?
Thanks...FRD
I would guess Warn would have a direct install or the dealer. I would think Harbor Freight would NOT fit directly as they are built for the universal market. You will have to make some kind of adapter plate and bolt or weld.
rocmoc n AZ
    • By dman66
    • By PossumTruck
      Greetings,
    • By Kingfish
    • By Brett
