Here is a rough schedule of next summer's trip with the Trooper. Anyone is welcome to join on all or part of the trip. I pretty sure Kinarfi is going to Killpecker with us.
June 7th-12th Moab, Ut (norm temp 92-96)
June 13th-15th Dinosaur National Park, http://www.nps.gov/dino/index.htm (norm temp 84)
June 16th-19th Vernal, Ut, http://www.4x4now.com/trutvr.htm (norm temp 85)
June 20th-23rd Killpecker Sand Dunes just north of Rock Springs, Wy, http://www.duneguide.com/sand_dune_guide_killpecker.htm (norm temp 76)
rocmoc n AZ
Trip has moved one week later as we had to tie down a reservation for our stop after Killpecker Dunes. Moab is dependent on the weather. If the forecast is cool with a storm front crossing Washington & Oregon, then we will go for it. If it is going to be HOT HOT HOT we will forgo Moab. Trip will start with DINOS.
rocmoc n AZ
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By MMaster
      does anyone know of a replacement temp gauge that will work on a joyner 2016 r4, my gauge has condensation in it and it quit working
    • By MMaster
      looking for a replacement  temp gauge that will work with my joyner r4
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
