Need a good source for some steel wheels, also what is the lug pattern?
Ok I got the pattern --- 4-115.. still need a steel wheel source, I'm wanting to buy some cheap wheels to put street tires on.
You could also order a set from Pete Paulson wheels... I use to order my Dwarf car wheels from him and a friend just got a set for his Spec Racer.....
Just give him the bolt pattern and back spacing you want... Probly get 13"- 15" wheels with the Joyner pattern.
    • By GaryC
    • By klm
      So here is my dilemma, I bought a 2014 Massimo MSU500 eleven years ago from TSC, its never been off the farm, had my share of ups and downs with it but never walked back to the house. I have bought a Kubota Sidewinder and it is a fine machine.Problem is I just dont need the Massimo and would like to sell it but the last thing want to do is sell it (cheap) to someone who doesn't realize what a POS a Massimo  can be and can't afford to maintain it.  I plan to put it of Craigslist with pictures and description, not sure how to warn potiential buyers without scaring them away.  I feel like it could be a great buy for the right person or a terrible buy for the wrong person.  I'm thinking $2500.
    • By Kingfish
