Need a good source for some steel wheels, also what is the lug pattern?
Ok I got the pattern --- 4-115.. still need a steel wheel source, I'm wanting to buy some cheap wheels to put street tires on.
You could also order a set from Pete Paulson wheels... I use to order my Dwarf car wheels from him and a friend just got a set for his Spec Racer.....
Just give him the bolt pattern and back spacing you want... Probly get 13"- 15" wheels with the Joyner pattern.
    • By Kingfish
    • By Ridge Runner
      thanks
      Ridgerunner
    • By diamondjfarm
      Thanks.
    • By sxr951
      2015 massimo 700.. need cylinder bolt!  it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm  dont know where to find any ideas? thx
