Any one know of the best replacement part for oxygen sensor.Thought i read something about this some time back,but can not find. o8 T2 Found someone who usedNTK25156 .has any one else used these? not wireing ,check it out.
In the past, people have had a problem with the wire to the O2 sensor rubbing bare and shorting out. Also another the fuse to the O2 sensor failed. Kinarfi & Lenny are the most experienced with the sensors. In the future we need to use Oxygen Sensor instead of O2 so the search function will work. Search functions requires 4 letters or more for a search so you have to use sensor and wade thu a lot of stuff to find the Oxygen Sensor info.
rocmoc n AZ
Welcome bill and mary, please fill out the profile so we can all get to know you a little better, & who knows, maybe one of us lives just around the corner from you.
check the wires where the go past the radiator, if held in place with a tyrap, cut the tyrap and re-secure the plug to keep the wires away for the radiator support, that's where mine was shorting out.
Rocmoc, as moderators, we can make changes like you suggested, so I did.
    • By Cory J
    • By se3388
      Steve.............
    • By Jacob E freeman
    • By mark walkom
    • By Reynolds Rocket
