Oxygen Sensors
bill&mary
In the past, people have had a problem with the wire to the O2 sensor rubbing bare and shorting out. Also another the fuse to the O2 sensor failed. Kinarfi & Lenny are the most experienced with the sensors. In the future we need to use Oxygen Sensor instead of O2 so the search function will work. Search functions requires 4 letters or more for a search so you have to use sensor and wade thu a lot of stuff to find the Oxygen Sensor info.
rocmoc n AZ
Welcome bill and mary, please fill out the profile so we can all get to know you a little better, & who knows, maybe one of us lives just around the corner from you.
check the wires where the go past the radiator, if held in place with a tyrap, cut the tyrap and re-secure the plug to keep the wires away for the radiator support, that's where mine was shorting out.
Rocmoc, as moderators, we can make changes like you suggested, so I did.
    • By Reynolds Rocket
    • By John M in Louisiana
      Thanks in advance!
    • By Kingfish
    • By hetovi
      Hello everyone.
