Has anybody replaced tie rod ends? seems like there should be a part to replace with.factory part sucks.
Thanks,plumber. Do these have dust boot? Also why didn't you get theMHMR-16z,they have grease fitting?
I didn't see any dust boots I did get the mhmr-16z But the grease fitting is so small that they broke off just geasing them so I bought the mhmr-16t.
also theses look different than mine.mine don't have through bolt. they look like the ones on ebay #270793660912.he says these will fit just don't want to replace with junk.thanks
I'm sorry they are rod ends you need tie rod ends the ones I showed you goes on the a-arms.On the tie rod I replace mine with stock one I don't know of any tie rod ends sorry about that
  • 2 months later...
The tie rod ends on e-bay 270793660912 will not work the are for smaller joyners, threads and shaft size are different. I e-mailed them and asked about threads I don't remember the size but they were wrong. I got mine from JMC motors. Call them to make sure you get tie rod ends not ball joints. I had a small problem, when I ordered them on line the ware house sent ball joints, talk to Casey he will get you the right part. there is a problem with descriptions. They call both ball joints. I would also recommend changing the zerk fittings. They treated me great, corrected my problem no hassel.
    • By Grant
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By mark walkom
    • By Fordman1
      Cleaned fuel filter and am replacing mechanical fuel pump. Unbolted but can't get fuel pump out. Shaft sticks out and fuel pump hits axle and won't come out. Anyone had this problem?
