Hey guys any suspension tricks out there for the trooper, to make it a little more friendly at the higher speeds??? I know we have all talked about the steering issues but is there any tricks to getting that free play out of the wheels does that kit I have seen on ebay take care of it.. Oh ya Rocmoc I did put the 30" tires on my T2 you werent kidding gearing is way better now thanx for the info
The kit is the best option until we can find a better steering box. The kit works quite well. Check for loosness through the entire steering system (tierod ends, steering shaft, u-joints, wheel bearings etc). Once you get all the play out & add the steering kit it should drive quite nicely at speed.
thanx Ill give it a shot
    • By Dennis
    • By A P
    • By strike250
      Matt
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
