Went for a ride out near Stockton, Utah & up to Jacob City
When I got there, I was quite disappointed with the looks of every thing, but ended up staying 3 nights and riding for 4 days, These trail are NOT fire roads, no problem for our Troopers though. I have found that my Trooper eats up trails to easy and fast, that what take quad riders day to do, I do in a day, maybe I don't stop and spectate enough. Rocmoc, Lenny, I'm sure you'd like this area, there is a great county camping area with rest rooms after you get past Ophir that can handle Rocmoc's rig. This is genuine mining roads and some of it is STEEEEEp. Lots of junipers, pines, aspens and rock and cliffs and mountain tops.
http://rides.webshots.com/album/581565755itjeRf
If anyone wants a .gpx file of the 4 days rides, PM me with your email address.
Sounds like somewhere that we may have to add to next summer's trip when we come up your way. I will take a look at the historical weather data for June.
Who was the UTV in front of you in the videos? Looks like it was a little cool, sweatshirts ! I think you pick out big mountains just to see what is on the other side, LOL.
rocmoc n AZ
rocmoc n AZ
Just another friendly atver, don't know if I even got his name. Yea, big mountains, love 'em, and it's always an adventure to find out what's on the other side, seeing the same old stuff gets boring, I wanna see new stuff!!!
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By SayHiToRambo
      08 trooper 1100
      thanks!
    • By Ken rung
