Joyner Trooper Signal Lite Flasher
rocmoc
Found another difference between my 2008 first 50 Trooper & the later ones. My Trooper takes a special signal flasher with a pigtail. Found one on ebay for almost $60 in England. After the first 50 or 2008 the fuse box is different that a more regular USA type flasher was used, at least that is what I found when I went out to rob the one off of my 2009 dismantlement Trooper.
I am going to do something different and if anyone see a problem, please let me know. I am going to purchase a regular USA type flasher, cut the female connector off the wiring, add plug ends on the wire and plug the USA flasher directly into the system. Only problem I see is figuring out which wire of the three goes where.
rocmoc n AZ
rocmoc n AZ
http://www.google.com/#sclient=psy-ab&hl=en&source=hp&q=automotive+flasher+wiring&pbx=1&oq=automotive+flasher+&aq=1&aqi=g4&aql=1&gs_sm=c&gs_upl=8122l15191l0l19437l19l13l0l5l5l0l274l2688l0.6.7l18l0&bav=on.2,or.r_gc.r_pw.,cf.osb&fp=1c82949ca002f577&biw=1692&bih=736
rocmoc n AZ
This is my best guess, but if you want to use the one of your 2009, assuming it's like my 2008, you feed it with a hot and a ground and then the out from it goes to the signal switch and to the light, maybe that a DUH! If you would like, I'll look at mine and let you know which is which and what is what.
Kinarfi
The 2008 & 2009 are NOT interchangeable. Entirely different. 2008 is an electronic module with a pigtail at 20+ times the cost. 2009 is somewhat like a standard USA flasher with the 3 male connectors, simple & cheap. This is how you take something simple, like our gas gauges, that has worked forever and turn it into a more complicated piece of cr*p.
rocmoc n AZ
rocmoc n AZ
Hi rocmoc........I have a 2007 Joyner SV 1100. The flasher pulsates like a thousand times a minute along with the lights. It's the square kind with the pigtails. I tried a standard flasher but keep blowing the fuse. Have you figured out how to use a standard flasher?
Bruce
Bruce
Hello Bruce,
Mine was doing the same thing. I tried the old style flasher but did not work. Kinarfi or someone else may jump in but my opinion is the new flasher uses a much lower amperage because of the micro technology. I have not come up with a solution except finding a fair priced supply which I have not found yet. I will post when I find a fair priced vendor. They do have similar at Autozone but have not tried any.
rocmoc n AZ
Hello Bruce,
rocmoc n AZ
Thanks rocmoc...........if I find something I'll post it.
If your trashing your old flasher, can I have it so I can disassemble it, maybe redesign it and if I'm successful, I'll make one for you too. The one in my Trooper puts out about 16 - 18 volts when it's not blinking which says to me that it has something weird inside it.
Here's the schematic of the flasher wiring, according to the manual, I looked at the link Lenny supplied and from my experiences with flashers, it may be a simple change of flashers, I don't think they're all the same, this may be the answer,2455785240104110397ovhYGs_th.jpg http://www.bugmanweb.com/gsxr/gsxrimages/flasher/flashfixdiagram.gif, just add a resistor in parallel with the lights because our signals don't pull enough power to get a good heat into the flasher like the bigger bulbs used in cars, this will be more true if you changed over to LED lights or get the electronic flasher which does not care how much current flows.
Kinarfi
Kinarfi
Kinarfi, I am emailing you directly.
rocmoc n AZ
Kinarfi
Kinarfi.......you can have it. E-mail your address to me and I'll send it to you. My buggy is a Sand Viper. Are the flashers the same as the Trooper?
    • By Havoc321
      I’m looking to have my 2022 800sx fit in the 10’ garage of my toy hauler. I thought about removing the dump bed, so I wondered how far the dump extends beyond the tires.  Thanks!
    • By Xov
    • By Hugh
      Hugh
    • By Ron from the Mitten
      I purchased a 2008 Qlink Rodeo 700 a few years ago.  I am from Michigan.  Anyone know of any local repair shops?  I had a dead battery, so I replaced that, started right up, ran the quad down the road, (this was last year), put it in the barn, shut it off.  then a couple weeks later, went to go start it again, and nothing.  I have power to the dash lights, horn, turn signals, wench etc, but nothing to the starter switch, and I hate electrical crap.  Battery still reads 12.x volts.
      Any suggestions would be amazing.  I've owned it over 2 years, and haven't run 1 tank of gas through it.  No time to screw with it, and very frustrated.  Hoping someone can offer some advice of value.
    • By alevins
      Good day all,
      searching here but cannot find the answer,  Hisun been working fine and now reverse limiter seems to be engaging and cannot back up, cannot find a clear solution to disable the limiter. found a possible relay?  not sure which one or to cuut a wire at ecu but a picture or diagram would be helpful
      thank you for any help in advance
