Making Changes, new look
By Michigan sport.
I'm sure many of you are aware of Michigan's emergency brake requirement. I'm wondering if anyone has a good solution.
Beyond paying the few fab places $$$$.. I'm curious is there another rear caliper with e brake style that would interchange with slight mods to the Maverick sport rear mounting bracket?
By JSwearer
Does anyone have any suggestions for aftermarket shocks. I have a T-Boss 550 and took it riding in some rough trails and the stock suspension was uncomfortably rough.
By Paul Angstadt
Paul
By Farid
Hey there,
I’m trying to find a CVT (variator) for my Tracker Off Road 800SX Crew. Do you happen to have one, or know where I can get it?
Also, if you’ve got any other parts for this model, I’d love to hear about them!
Thanks a lot!
