Reared Issues
By KWinTX
By Jon Spruill
By Pick a name
The Axis 500 will not shift into low or reverse. I have high when it should be in low and all the other places it is reverse. The gears in the shift cover are fine and I shifted it when the cover was off and yet no change (so it can't be the shifting mechanism gears). I t has been difficult to get it into low for awhile. But now it is either high or reverse, no neutral either.
By lincolnsq175
I have a 2020 coleman ut400.
Any info is appreciated.
By Flanman55
2007 Hisun HS700 will not crank. Replace the ignition switch. Same thing. Replaced solenoid by the battery same thing. Can jump it and it starts good across the solenoid posts. Ran a jumper wire from switch to solenoid. Nothing
