    • By Rizzguy
      Don’t waste your time everybody with rpm motorsports, Omaha. They are people that don’t even work on sxs’s. Trying to tell you how to install things.
      Completely uneducated guy tried to tell me I did not install a mid pipe correctly when it won’t install correctly; that was the reason for the video and the complaint that I called him about.
      This mid pipe has a 1 inch gap at the rear, and the only way to close it up is with a longer bolt, and to stretch the flex at the Exhaust
      After one ride, the rear bolts have disappeared, because how much tension there is on the flex
      And the bolts does not line up at the flange
      Have a video before and after. And they are telling me that it’s my fault because it does not fit
      wtf.!
      What kind of idiotic people are even answering the phones these days.?
      This guy has probably only read a book and never even driven a motorcycle in his life
      Don’t waste your time with this bullshit products
    • By Kingfish
      I've had a battery failure and need one replacement.  The local distributor told me it might take up to four weeks to get one.  I'd like to order one in sooner than that if possible.  Any help would be appreciated.
    • By Mike Turner
      After 5 years my 2016,  650LandMaster is needing normal wear and tear service. But I can’t find a dealer service center to perform any of the work because I didn’t purchase the UTV from them. “I’m not going to help you” I’m told, “find someone else”. And apparently there’s not a damn thing I can do about it.
    • By scottkkk
      Hi Guys i need your help. what is the black yellow and blue wire for?  black for ground? what is the yellow and blue for?
    • By chadchat
      I was wondering if anybody out their has had trouble with SEDONA Tires.
      I purchased 4 each Sedona Rip-Saw R/T 28x10-14 and after 1500 miles they are showing large cracks on the side walls of the tires. Some of these cracks our 2 to 3 inches long and a 1/8 to 3/16 of and inch wide. There is up to twenty cracks on two of the tires. i do not dare drive on these tires no longer. Please help as i have lots of miles left on the tread. i store my bike in my garage. SEDONA tire told me that it was a LACK OF PROPER CARE. I clean my tires after every use. DONT BUY WHATEVER YOU DO,YOU WILL BE STRANDED AND THEY DONT BACK THEIR TIRES. I bought these tires from Rocky Mountain ATV believing they were bullet proof for mud, snow, and hard pack roads. I even talked my brother and friend into purchasing the same tires. My brother is seeing these cracks also and has a none repairable leak on the side wall were lug of tires wraps around. I just wish I would have found out more information about SEDONA tire before I made my purchase. I don't recommend purchasing SEDONA Tires.
