Mule 3010 parking brake switch
Tincup
Where is this switch located? Is it under the rubber boot protecting the brake mechanism?
I have an '05 3010 and the parking brake light and high water temperature light don't come on. However, the radiator fan runs and it's powered by the same switch that powers the light. I don't know if I have bad bulbs or what. I can find no easy way to remove the bulbs to check them.
Any pointers?
Thanks for your time.
Tincup
Here's an update. The water temperature light bulb is fine and won't come on until the temp is above 105F, I have no way of easily checking the water temperature, I'll wait until summer in the SoCal desert and check it. The parking brake light switch is on the brake handle, my problem was simply a dirty contact on the switch. I burnished the contact point and applied a small dab of No-Ox and it's working fine.
Coker737,
OK, here's the real deal :) ! After reading the shop manual and looking at the schematic, I don't see how the lights would come on momentarily when you start the rig. There is no ground offered to the switches to turn on the light, none that I can see in the schematic. Also, the temp light comes on between 226F and 237F, not 110F, it was 110C DUH :wacko: my bad.
Instead of doing my reading in the morning after my first cup of coffee, I should wait until later in the day after I've had my first cold adult beverage :D !
Paul
    • By mac66
    • By Ronald
      Check engine light comes on after engine runs continuously for 5 minutes or so.  I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so?  What ya think?
    • By Clint
      New to the side x side experience.  I bought a Coleman 550 Outfitter and I've seen conflicting comments about whether to use high or low range for running around under 15 mph.  Comments?
    • By sxr951
    • By Jason S
      Good afternoon,
      I have a 2022 Bobcat 34XL.  Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start.  Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
      TIA
