I am new to the sand rail circuit. any pros and cons for the Ecotech engine with 091 bus Transmission. looking on buying a used sand rail with this setup
THANKS !!
Silverbullet
The ecotech motor is a good motor.Is it a 2.2 or 2.4.The 2.4 is a great motor we turbo charge them to 360 H/P with no mods and it loves it.The 2.2 is not as strong i would bring it to a shop and let them check it out before you buy it.
Here are the spec for the one i want to buy. I alos noticed do you sell rails also
2007 Joyner
4 cylinder super charged eco-tec engine
091 bus trans, brand new rebuild close ratio gears
930 CV's new
Brand new axles
Aluminum radiator for engine-With electic Fans
Aluminum radiator for super charger-With electric Fan
Brand new brakes
Hydrolic clutch
Kennedy clutch and components
Brand new Willwood Rear Brakes
Full gauge package in dash
Ipod hookup in dash
6 HID lights
2 paddles tires
2 front sand tires
4 matching wheels and tires for desert
Brand new fuel regulator-
MSD fuel Pump
All New Fuel Lines
Optima battary
    • By aefron88
    • By SSgt1994
      Myron
    • By Steve Waldner
