Remove passenger seat. It's a typical m/c type dipstick on the side of engine. If you need to add or change oil, be certain it's WET CLUTCH approved engine oil. Full synthetic auto type oil will fry you clutch quickly.
If it's like the outfitter 550, pull the center and right side access panels under the seat for best view and access to the dipstick. Unfortunately the aftermarket dipstick extension tubes won't work since they extend up under the non removable portion between the access panels.
    • By Frank in MI
      Thanks for accepting me!
    • By hisun junk
    • By Howard Elmore
    • By JSwearer
    • By Justine
