Master Cutoff Issue (not alternator!)
By downseast
Hi everyone
By Roadstar515
Regards, Rick
By boydog40
thanks guys
By Reynolds Rocket
I have a 2017 Intimidator XD4 800cc 4x4. It will run great and then it's like it goes into safe mode and only runs on 1 cylinder. It's not fouling out the plug when it happens. Some times when I stop and restart it, it works fine. First I thought it was a spark issue, then a fuel issue, but I feel like it's a short in the wiring some place.
By lmarkie
I swapped out the Subaru motor for a Predator 670cc. If I remove the heat shield around the muffler, The stock muffler sits in there just fine with 1" to spare.
Only problem is the exhaust exit is toward the back seat instead of out the back.
Do you all think that the stock exhaust would be okay (just as effective) if cut a hole and welded a pipe on the reversed (opposite) end? Of course, plug the old exit end. Other option I thought of was to roll a tube 180° with a 7" center line radius and finish extention of 12" or so.
Any thoughts?
