I know of at least one Trooper owner that blew the front diff. I would jack the front up and rotate the wheels and see if I could locate the source of the clunk before I got too alarmed. Check diff mounts, CV joints as well as the diff itself. Sound can travel so could even be the front driveline. Good luck!
rocmoc n AZ
Devildog,
One last thing to check before you pull the diff. Make sure the locker cable is fully engaging and disengaging. If only partial, could be slipping on the edge of the teeth of the pinion nose. Adjust or disconnect the cable and make a test drive.
rocmoc n AZ
    • By Karlibob
    • By Ed Michael
      Subaru SxS.mp4
    • By Unhappy Kioti K9 Owner
    • By Blair
