STEEL EXHAUST FLANGES RHINO 660 / RHINO 700
TIRED OF LOOSING EXHAUST NUTS? OR EXHAUST LEAKS THAT ALWAYS COMEBACK?
KMS Performance has the solution to warping and leaky aluminum exhaust
flanges. A pair of 3/8†steel exhaust flanges that won’t bend, warp or leak due to heat.
These flanges were designed to repair after market exhaust headers, that were [...]
View the full article
      Coleman UT 400 has a strong sulfur/emissions smell from exhaust all the time.  Kind of like it’s running rich and a catalytic converter is trying to make it run cleaner so it smells bad. Also misfires when warm. Idles fine. Full throttle fine. In between it cuts out. Do these have catalytic converters?  Almost acts like it might be clogged if so.
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By Brett
    • By mark walkom
    • By amiracle40995
