Check your gas tank
Just found cracking in the weld around the filler tube and a near by seam. These are the factory welds. Suspect that the vibrating of the filler tube is causing fatigue. I sujest that everyone monitor their tank for cracks on a regular basis. Mine showed up when I filled the tank and on up into the filler tube. Couldn't see anything come out as it's all but invisible to see but I did see the dripping under the tank. Use a paper town around the filler spout after filling up into the spout. Mine left about a 14" diameter spot on the floor. Wouldn't be good to flood the under panning with gas followed by a subsequent fire.
That's interesting because that is exactely what I plan to do to mine. I now have it out and I'm letting a fan run air through it for a few hours to get rid of any fumes. Should get it welded and back in this afternboon.
you can fill it with argon to back prudge it, or hook it to the exhaust of you car for awhile then weld it
Never done it that way but have heard others have. My main concern is to give it time enough to assure that all the gas that that may be hidden in the cracks of the seams has had time to evaporate out. Thanks for the input.
thats the point of back purdgeing with argon or running a hose to a tailpipe of a running car
I weld a car tank once after filling with soap & water. After it was full with the water & suds, we place a flame in the opening. Small pop and that was it. Still was scarey!! This was when I was young & s****d, I can't write it. I was yound and a lot of fun. Luckily I still am, LOL!!!!!
rocmoc n AZ
I had my tank out for leak repair and problem was cracks around mounting tabs.
Had them removed, welded new tabs with triangle gussetts (sp?) underneath each tab. Used rubber washers for cushion/vibration isolators under each mount.
Seems to be fine now.
Also moved filler from back of tank to top so I can fill it at gas station instead of using gas can (it wouldn't handle the flow from pump before).
Oh the joys of upgrading Joyner's!
Anyone have any problems with gas leaking out from the plug on top of the gas level assembly? Other than that, my 08 tank is just fine, with no cracks I can see. Then again, there's only 1k on the machine.
I had same problem. Had to replace the fuel sending unit in tank. Leaked from red wire port on top. I got mine from Casey at JMC. Good luck. Be sure to measure length before you call to order.
Guest Lenny
Mine leaked there and I used some good gas tollerant sealant and cauked around the area and that has solved the problem.
Guest Lenny
You should be able to do it from the outside. Give it a chance to set until cured.
    • By BMurph
    • By BMurph
    • By Cory J
      Belt started slipping when I used it in high gear. It works okay in low unless I'm trying to power it up a hill and then it slips.., Ordered a new belt and went to change it and found a good bit of oil in the belt housing. Has anyone experienced this? Belt looks fine. Only have 300 miles on this thing..
    • By NHTracker
      I have a 2020 Tracker 800SX LE that I bought new in 2020.  Yesterday I noticed two cracks in the bed on the inside corners at the tailgate end.  They go all the way through.   I use it around the property moving firewood, dirt and stuff.  Never put stress on the sides of the bed.  Has anyone else had this problem?  Is there a fix?  Help!!!
    • By Joe Breaux
      Everybody out riding? Awfully quiet here recently. It's so damn hot here .We expect 112 to 116 heat index tomorrow..getting too old for that heat.
