Hmmmmm
By diamondjfarm
Thanks.
By Kenbaz
Well, the subject says it all! After the motor stopped, I went out and bought gas and filled the tank. Tried to start and it just cranked - no fire. I assumed I had spark, because nothing changed there. I pulled the plug and could not smell gas. The plug was dry. Put it back in and tried to flood it by piumping the pedal, but it was still dry when I took out again.
The gas gage red fuel lights didn't seem to recognize that I filled the tank (see previous fuel Haugen posts). Disconnected and reconnected the negative battery terminal hoping it would reset any interlocks that might be set. Now the ignition panel will not light up when ignition turned to "On". Things are getting worse instead of better! Have the fuse panel open, will check fuses tomorrow. Can anyone help me get back on track? No shop here in Tucson will work on it! Nice unit. But you're on your own for maintenence. Thanks for any help!
By Greg Kilgore
We all know summer is hot inside the cabs of our SXS. So I've rigged up a couple of fans to help cool down the cab.
I didn't want to drill the fan's "support rails" into the ROPS (Roll Over Protection System), aka roll bars. So I used water clamps to hold them in place.
I just need to replace the wires I ran with bigger gauge. Then finish the wiring to switches, relays, and battery. But the hardest part. The actual mounting of the fans is complete. Also just in case anyone plans on doing this. I may have to only use 1 fan in the middle instead on 2. Due the the draw on the battery.
The fans are 12", 12V 80W. So I'm figured they were 6.7 amps apiece. Used the WAVe formula to get unknown values Watts=Amps*Volts then solve for unknown. I know the watts and volts from sticker on fan. So just used above formula to get amps. So a 7 amp fuse should be OK and a 10 amp fuse will be good.
So pulling 14 amps from the battery all day may be too much for the charging system to keep up with. And I haven't even installed the radio yet. So I will have to test and let you know.
See pics below.
By Daniel Goodwin
Hi,
I have a brand new Hisun Sector E1 that I got in March-April timeframe. Its got about 100 miles on it. I was driving it yesterday among some tall grass on one of my hills when it just complete stopped moving. Pressing the accelerator and nothing. I put it in reverse, nothing. I tried in 2 wheel and 4 wheel drive, locked and unlocked. Nothing. I put it in neutral, turned the ignition off and started it again and was able to drive forward about 20-30 feet and it stopped again. No errors. No 45C message, nothing. Just completely unresponsive. I had to "limp" all the way home by turning it on and off to get home. That 30 feet or so that it would travel was full power, I could push it hard or take it gently and it would still cut out on me. Its super bizarre. Anyone have any ideas what might be going on? I'm no electrician...I thought buying a sector E1 would require less work from me than an ICE vehicle, it appears I was wrong. I'm 2 hours from the nearest distributor so pretty worried about getting it serviced.
