CVT transmission
By donny
By Pop Bob
Just bought my first SxS 4 days ago. Looking forward to hitting some trails and back roads. Having a few issues with the machine(Vector 500), but nothing serious. Just setup and tweaking. I would like to by some accessories, but I don’t seem to be able to find much which is machine specific. Or at least my machine. Does hisun offer accessories? Any advice would be appreciated.
By Alien10
By sister sweety
By Buddee
Any help appreciated!
