  • 3 months later...
I did take the dash and the glove boxes out off of my 3010 when I was working on the hood and cargo compartment. Is the problem with the hood latch? or is it possible the way the hood is mounted? I bought a 3010 that TPO had pop rivited the hood on at one time. I squirted the hood latch full or PB Blaster several times and then forced the latch handle in really hard at the bottom of the handle and got the hood to pop open. There wasn't any hood opening hardware left, TPO had a rubber bungee strap holding the front of the hood in place. I since then have took pictures of hoods at a dealer and ordered all the pieces, bolts, screws clips that are on the hood and after a long learning curve have it all together and it works fine. I used the parts diagram that is downloadable on Kawasaki.com to learn a lot about how the hood and hardware go together.
It is esscential that the hood be able to be opened in order to check the coolant and the brake fluid
Thanks much MrOkie. By removing some screws and dash components, I was able to pry around and get both latches open. I believe now it has been in a pretty healthy front end accident as nothing lines up good regarding the hood. The exquisite hinging system is pretty bizarre and can't see anything bent.
Can you recommend a good shop manual?
Rick
    • By Rick A
    • By Brent C
      Hi all, I own two Axis UTV's. Last year I purchased a 2022 Axis 500. I had a mechanical issue with the shifting forks after only 50 miles. I contacted Axis/Hisun warranty dept. That were very helpful and willing to send out a representative to see if it was a warranty issue that fell under coverage.  Since I live in an area that does not have authorized repair facility within 300 miles. A really nice guy drove all the way from West Virginia which was 4 hours away. He determined that the console would not stay seated in position and while driving it, the console would jump forward and knock it into the wrong gear causing the shift forks to become bent. It was then picked up a few weeks latter to be repaired in Richmond, Virginia. It should arrive home soon.
      Now to my question. After the 2022 Axis 500 was taken for repairs, I bought the 2024 550 Axis. I bought the first one to take my son who is disabled from an extremely rare disorder that requires daily care to get out of the house. There are two things that give him joy, music and going for rides.  That is why I purchased the first one, However because it had bucket seats and the engine was between the two and was too loud even though I deaden the sound and put a quiet muffler on it.
      I then decided to purchase the Axis 550 for the great updated features and the bench seat, I will be buying the complete enclosure ad on's offered by Hisun. Since it does not come with a heater (Axis 750 does) I was wondering if anyone knows what heater is part of the 750 edition. There was a photo that showed a Firestorm brand, however I can not find what variation it is. If anyone knows what a Inferno heater would be correct for the Axis 550. I would like to install it this Winter to take Justin riding on the farm. Any help would be greatly appreciated.   Brent
    • By Poppateets
      I just purchased a used 2023 Massimo warrior UTV SxS 1000mx with 600 miles on it. I didn't even get a full day of riding and the driver's side rear axle broke. I'm pretty sure it was already going bad because we would hear a noise once in a while. I'm wondering if anyone else has had problems with theirs. Also looking for places to buy accessories.
