Trooper Rear End
By BMurph
By SouthernGypsy
By Ductking1
I recently purchased a 2024 Hisun 550 Sector from Kreps Service Station and am having issues with the gear selector, I am doing as instructed in the owners manual but the shifter acts like it is binding or the button lock isn't releasing, the shifter will not move, I have to wiggle it back and forth while pushing hard on the brake and if it's in park or reverse it's nearly impossible to get it to move, I contacted Justin Krep and he says this is normal with these machines, I find that hard to believe, I've owned many utvs and side x sides and have never had this kind of issue with any of them, any help with this problem would be greatly appreciated.
By Justine
I've had a Hisun Vector E1 for just a bit longer than is required for me to do some maintenance. While it's well-overdue, it only drives 1.5km a few times each week on a fairly decent gravel road (to the letterbox), and it has worked really well right from the get-go.
Looking at the manual it states that I need to use SAE80 API GL-4 Hypoid Gear Oil for the Main gear Case, and SAE80 API GL-5 Hypoid Gear Oil for the Front gear Case - unfortunately i can't find either of those online here in Australia. Plenty of options that look close, but, as someone who has never driven any vehicle before, I want to use the right thing and it's a tad confusing.
My question: Since there are no oils that are bang on SAE80 (they all seem to cover a range) would Liqui Moly Hypoid GL4 Gear Oil 80W-90 & Motorex Hypoid GL-5 Gear Oil 80W90 - be ok to use? (Or any other suggestions of what I might be able to purchase online in Australia) And would I have to drain out any existing oil from both gear cases?
This is a whole new world for me and being able to find exactly what is specified in the manual hasn't made this easy!
