Does anyone know if Mauy Thai1 is still around, I sent him a PM on the 19th and have not heard back. I want'd to know about some injectors he has.
best i can tell is he hasnt been around since December.
He lives in Grand Junction, Colorado. His name is Robert, can't remember his last name. Call the Grand junction police department or sherrif department. Just ask for a Robert that is a national marshal arts champion. They will all know him. He is obviously one bad ass dude. Also maybe Kinarfi can help. I think he was going to ride with him at one point and probably has his phone number. He had an over boosting problem which I wasn't able to help him with.
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By mark walkom
    • By Kingfish
