injectors
lowgear
He lives in Grand Junction, Colorado. His name is Robert, can't remember his last name. Call the Grand junction police department or sherrif department. Just ask for a Robert that is a national marshal arts champion. They will all know him. He is obviously one bad ass dude. Also maybe Kinarfi can help. I think he was going to ride with him at one point and probably has his phone number. He had an over boosting problem which I wasn't able to help him with.
    • By Jon V
    • By mac66
    • By sxr951
    • By Joe Breaux
      just an update on my MSU 500 . For all the misery it caused me the first 2 yrs, and the combination of some quality YAMAHA parts, it has now become a reliable ,useful UTV without the constant fear of having to push or tow it back from trails. I have not had a single issue pop up in a very long time.. FINALLY!....and as a side note, I just bought  a C FORCE 600 ATV to replace an old and well used  Honda that finally after 18 yrs gave up a rod bearing.  So far the new one has really impressed me .. I like the new Power Steering and  this CVT Auto Trans is new to me on an ATV .. I m used to constant shifting on my Hondas .  It also has something I have never seen. Its EBS  engine brake system, as soon as you let go of throttle, it engine brakes you to a stop rather quickly.. its great idea for the grandkids safety . Takes a little getting used to tho.. All in all, I like it. We shall see how durable it is after break-in.. I do "RIDE" them! .....and they honor their warrenty! and the dealer is 15 minutes away..
    • By BernieG
