i was on the phone with No Limits Powersports asking about buying a new Trooper T2 for my buddy...
i was told they were bought out and resumed buisness and also that the 1100cc Chery motor was built by
John Deere, and i could buy parts for the motor from my local John Deere dealer... has anyone else heard
this? is he full of it or truthful? i am asking because i am going to order the cams and rebuild the head and need a top end gasket kit....
and sorry lenny like i said i took my starter to a local starter & alt. rebuild place and the guy there told me it was a Mitsubishi starter and he did put a new motor and solinoid on it and did it in only a few hours... i will try to get by there asap and find out exactly which year make and model it will fit... i know the fron housing has to be reused but the motor and sol. are mitsu...
Guest Lenny
I would think so. I beleive that Cheryt only makes one 1100cc engine and if John Deere is using their 1100cc then the parts should be idenical except for maybe some minor changes from year to year. Head gaskets, oil pumps, etc.should be the same. Just make sure you get clear confirmation from John Deere of the engine they are using.
Chery engines are made by Chery and used by many Off Road and On Road Vehicles. The JD engine is the Chery 812cc and is the same as the Joyner Renegades. JD followed Joyner after testing the engine out. JD has the Auto Trans and is down on power a bit from the Renegades Manual Trans set-up. It’s the fastest ever Gator but against Joyner it’s behind both the Trooper and Renegade.
Cheers Mike.
cool i will get that starter info posted asap. do i post it directly on the crossover thread?
Just post the info here and the mods will copy or move the info.
rocmoc n AZ/Mexico
  • 3 years later...
Silverbullet
Joyner Parts Wholesale.We have just received our bearings 35x65x35 SKF.We have worked vary hard to make this deal.Well it paid off.These bearing are made in GERMANY!Another way we haven proven
we work vary hard to bring the JOYNER community how we are commented to bring you the best parts.Now we can offer trooper owners the best bearing you can get.No Chinese junk.Dual tapered roller bearing.Silverbulletmotorsports.net.Or call 928 344 2117.
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Bobbers
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
