WOW! he sure has made a lot of mods to it, and for 5500h. that sure seems awful cheep but it does look good. Bed looks like the one off the Rhino. I wonder how he has it set up to dump.
    • By mark walkom
    • By Reynolds Rocket
    • By lmarkie
      Any thoughts?
    • By redneckred
      Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X?  I played with the gauges once and lucked up on this but can't remember what I did.  Will the codes automatically display if there is a code or do you have to cycle through the display?
    • By aefron88
