How to wire a C/B into a dual battery set up
By Paul L
By Gorj
By Gorj
I am into five years of ownership of my electric side by side and I am noticing some deterioration of power. Although I measured the voltage at over 49 volts, I believe the batteries are beginning to fail. I charge them about twice a week. Last year the charger went out and I replaced it with a 48 volt golf cart charger. What has been your experience with the batteries?
By Jim Kessell
2005 American Landmaster
EH65 Subaru Robins
