How to wire a C/B into a dual battery set up
By LarryLarryQuiteRepairy
Hello,
Background: Bought a used 2012 700, added 2 small LED lights, wiring for a sprayer and changed front CV axles.
Had no electrical issues until recently. The old battery stopped charging so we got a new one, Rhino still wouldn't charge it.
-Started next day, drove 15-20min, then out of nowhere the check engine light came on and temp too. 4WD started to automatically engage and disengage repeatedly. Charging display started jumping all around between 11 to 13 to 15v.
-Relays, fuses, and battery connections seemed good.
-Continuity on rectifier would jump btwn OL and 00.0
-Rectifier wires from stator all read 20-21v at idle
-Rectifier diode test had 1 bad reading. So, I replaced it with a new one (but still using original plugs)
Started it up, still shows no change (12.1v idle, 12.8 with some RPM)
Also, I feel like now I maybe also smell burning plastic?
Does anyone have experience with this problem or have a recommendation of where to go next?
By Alien10
I added lights to the Coleman Outfitter 550 last fall. I bought lights on line from Nilight, a 300 W 12" light bar mounted forward and 2 square 4" floods for the rear. Those are mounted on the roof corners facing rear and downward just beyond the tailgate. Nilights seem to be of high quality, as I've had them on my garden tractor for 5 years and still flood the way ahead with great light.
Both the front and rear lights provide amazing illumination making the OEM headlamps look like parking lights. Made a connector for the front bar that plugs into existing headlamp switch so it is just part of that circuit controlled by the headlamp switch. Rear work lamps were wired in using a rocker switch installed in the dash. Backed up to the garden with the work lights and was able to harvest some tomatoes well past sunset.
What have you used if anything for auxiliary lighting on your UTV?
By hetovi
Hey everyone,
I recently purchased a CFmoto ATV and I'm looking to add some accessories to enhance its performance and usability.
I'm curious about what you all consider essential add-ons for a CFmoto.
Specifically, I'm interested in accessories that improve comfort, storage, and overall ride experience.
Are there any brands or products that you’ve found to work particularly well with CFmoto models?
Any tips on where to get the best deals would also be appreciated. Looking forward to your suggestions and advice!
By didgeridoo
By Greg Kilgore
