Guest Lenny
First off I would be sure the clutch is engaging fully. Disconect the slave cylinder fromt the arm that comes out of the clutch housing (bell housing). There should be a little of surplus play in the arm befor it starts to push on the throwout bearing. Where did you get the clutch? Is it susposed to be an extra strong clutch? I'm not having any trouble with my stock clutch and I'm putting out a good bit of power.
I too have not had any problems with the stock clutch. Did you have the flywheel cut? Seem I remember the kevlar clutch required some work to the flywheel.
rocmoc n AZ/Mexico
    • By BMurph
    • By Jerrys500
      Thanks Jerr
      I use my Hisun 550 (with the Coleman stickers), for general work around my 10 acres of hilly land. Hauling firewood, some dirt and mulch, and debris clean up. Also felling dead standing trees in the woods and hauling rounds out to the barn for splitting/stacking.
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
      Thanks in advance for any experienced thoughts and comments.
    • By Ductking1
      I recently purchased a 2024 Hisun 550 Sector from Kreps Service Station and am having issues with the gear selector, I am doing as instructed in the owners manual but the shifter acts like it is binding or the button lock isn't releasing, the shifter will not move, I have to wiggle it back and forth while pushing hard on the brake and if it's in park or reverse it's nearly impossible to get it to move, I contacted Justin Krep and he says this is normal with these machines, I find that hard to believe, I've owned many utvs and side x sides and have never had this kind of issue with any of them, any help with this problem would be greatly appreciated.
