trooper clutch HELP!!!
By Grant
By bms stallion owner
hello, my BMS Stallion 600 is having accleration issues. the manual fails to show final gear oil diagrams very well... I have the owners manual and suspect issue is associated to transmission , I want to check the level of the gearoil. I located a drain plug (but not the fill plug nor dipstick). It will run - but wont exceede 2mph. Troubleshooting suggestions or comprehensive manual suggestions? Thanks
By BMurph
By Jerrys500
Thanks Jerr
