800cc intake and exhaust port matches!!!!!!!!!!!!!!!!!!
By Kingfish
By Ridge Runner
thanks
Ridgerunner
By Farid
Hey there,
I’m trying to find a CVT (variator) for my Tracker Off Road 800SX Crew. Do you happen to have one, or know where I can get it?
Also, if you’ve got any other parts for this model, I’d love to hear about them!
Thanks a lot!
By mac66
By Alex
