Sock 650 intake manifold wanted
commando1
Hey anyone got a stock intake manifold they are willing to sell working on putting a keihin fcr on my commando and want to modify the manifold but I want a spare one to work with. Already got the carb on the stock manifold and it runs great with lots more power but I think there is more left as the stock manifold is really choked down.
How much you asking for yours huunz
Which parts do you want? If you want the whole thing, give me your ZIP so i can figure out shipping. Mine would have no guarantees like Silver Bullet might, but it ran when I took it off. I have the intake system, and also a snorkel with a Uni filter on top to get the intake location up out of the sand.
    • By mac66
    • By sxr951
    • By Bobhoops
      Where can I purchase a spare tire for my 700 utv? Thanks
    • By Oldman
      Ive got an American Sportsworks BD-200.  I can’t get the ignition switch to work, but if I cross the solenoid, it starts right up. Runs great.  Can anyone send me a simple wiring diagram for a switch and where the 3 wires from the switch go!   Any help is greatly appreciated!!!   Thanks!
    • By Buddee
      Any help appreciated!
