I am going to put in my pitch for a weight saving pinned thread again. I just received some Lightforce 140 Lance headlights I ordered. They are about 1/3rd the weight of the factory headlights.
Lenny has saved some significant weight by removing the front driveshaft donut.
I could post up the numbers that I have written down for the rear cage & spare tire.
I could post the weight of the factory shocks. Airshocks could save you tons of weight. Even my fox shocks are lighter than the factory shocks by a few pounds.
If you remove the factory lightbar (I do very little night riding), there is 15-25 lbs. Or, if you build a light bar like Kinarfi you would save alot of weight.
Guest Lenny
I like that idea. Of the many things I have done, one is to replace the steel plates under the seats with 1/8" aluminum. That saved 10 pounds.
Plastic off road lights to replace the stock lights. More about being able to see at night, but still a good weight loss. Took off the winch and wiring, there's nothing to hook it to in the sand anyway.
On the add side, welded on tabs for the flag, and mounts for the flashing lights.
    • By mark walkom
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
    • By diamondjfarm
      Thanks.
