New intake for Trooper
Silverbullet
We are going to make a new intake manifold for Trooper.It will be designed to make low end torque.
We are going to make it with internal cooling rods.We have a fab.guy on the payrole so things will get done faster.Will work with supercharger or Turbocharger or stock motor.The cooling rods will be inside intake it will not interfere with airflow.We are going to test temp with and without cooling tubes.
I'm sorry if I missed the info in other post but I think it's not there. I am wondering about the intake manifold you are working on,
Will it be in stock position or would it be flipped upright like some of the members on the forum had done with their stock manifold by flipping it over.
So would your intake manifold be designed to fit like stock or in flipped upside down position or both or what?
Brandon
Brandon
I'm also curious about this. Will it be flipped our standard?
    • By Kingfish
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
    • By Jeff S
      How to fix newer 800SX that gets stuck in LOW
    • By WCF
      Hi Joyner Gang
