Anyone have a part # that will fit a T2? My stock filter says it has 3/4 x 16 threads right on it.
ADMIN: Please change topic to 3/4 x 16. Sorry.
I used a wix oil filter they are a real good one the # is 51348 about 6.50 But the k&n filter is hp1002 about 10.00 and up
Dead on plumber. I love wix, once saw an article where a guy sawed a ton of filters in half and found wix to be one of the best. I personally use those on my generic cars, and KN on my performance cars. I like the one inch nut on the back and I thought they also had a "hiflow bypass at high psi" and "antidrainback".
WIth your oil cooler, 51348 matches up oil leak free with a 51712/25730 derale sandwich? 51712 appears to be an old part #
Accidently bought a 20 x 1.5 mm derale if anyone wants one.
This is the adapter that I used http://www.jegs.com/webapp/wcs/stores/servlet/ProductDisplayPopup?storeId=10001&catalogId=&productId=&itemId=990321&langId=&showValue=1 you will need to see with that k&n filter that the one inch nut might hit the motor mount I bought the 20x1.5 too then had to buy the other one
Thanks man. My truck actually takes hp1002, held it up to the stock filter right now, and its going to be tight. I think it will fit. WIthout suspension on the motor mount, close should be ok.
I also cannot tell the differnece on the pat #s for the sandwich adapters. I think they are the same. Let me know if you detect otherwise.
    • By Wolfpaak
      Kenny
    • By Aaron Colona
    • By Joe Breaux
