Trooper parts coming to Jamboree UPDATED 4/21 w Prices & Gone
Here is a list of Trooper parts I will bring to the Jamboree for sale. We will arrive around Noon Saturday and stick around until two hours before dark.
(Shipping is EXTRA if not purchased at Jamboree)
NEW Complete set of intake gaskets (two gaskets) - $30
NEW Exhaust manifold gasket - $20
NEW Two brake master cylinders - $35 each or $60 for two
GONE!!! NEW One rotor - $40
NEW Complete set of transmission stifter cables (one red & one black) - $90
NEW Starter - $110
NEW Two caliper mounts - $20
NEW Two of Lenny's diff upgrade kits - $90 each
NEW Rear hub seal - $10
NEW 4X4 electronic engager unit - $150
2 sets of very good condition brake pads (4 pads) - $25
4 old style caliper mounts, could be used to do a brake mod - $10
2 front diff 4x4 slide engaging units, bolts on front of diff between diff, driveline & 4X4 engaging unit - $45 each
1 left side front diff cover - $25
1 old style rear u-joint driveline - FREE with a $50+ purchase, one freebe per person
1 steering rod u-joint - FREE with a $50+ purchase, one freebe per person
1 batch of various diff gears & bearings (no ring & pinion) - $40
1 batch of various pieces of deck cover items - $10
GONE!!! 1 Renagade ring & pinion (check with me at the campground, maybe already taken but you never know) - $150
1 Clutch in very good condition - $30
rocmoc n AZ/Mexico
Roc,
Is the front 4x4 slide engaging unit you have the replacement for the electrical box?? Does it allow you to use a cable instead--like the 2011/2012's? If it is, I want one! Also interested in the one intake and one exhaust gasket. Not sure if I can afford you, but PM me some prices on those please.
Roc,
The slide unit is not the same thing as the cable / electronic 4X4 engager. Every front diff has the same slide unit bolted to the nose of the diff and the slide unit bolts to the driveline.
Intake is a set of two. One gasket goes between the alum intake and the stainless steel intake ports. The other gasket goes between the stainless steel intake ports and the head. I have not had a chance to think about prices but will very soon. Still working on the rigs.
My prices will be cheaper than the dealers! Fair but not cheap!
rocmoc n AZ/Mexico
Forgot,
One used clutch with very little wear. Looked the same as the new clutch when I replaced. Only put the new one in because I had the trans out at the time. I had already purchased the new clutch but was suprised well the old clutch was lasting and would not have replaced if I had known.
rocmoc n AZ/Mexico
Rocmoc - Sorry I never got down south to ride with you before you sold your trooper.Would be interested in the Diff upgrade kits, pm when you figure out prices. Thanks DD
Unsold items will be ebay after Jamboree at a later date with a reserve. Of course a big multi purchase will get a discount. Hope to go home without anything.
rocmoc n AZ/Mexico
rocmoc call me, we are short one rotor and i will buy a lot of the stuff from you
If I didn't give you two rotors, thought I did, then it is yours FREE! Will call today.
rocmoc n AZ/Mexico
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Bobbers
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
