Wheels, tires, and fenders for t4
Hey guys, I run a lot of country appx. 22 sections in Dryden Texas on the rio grande. I was looking to get some tires that can handle the rocky rugged desert terrain , and was looking for some suggestions. Also, we travel through countless patches of dog pear, and do not want myself or my friends getting bombarded with the spiny little bastards at 50+ mph.
Any suggestions would be greatly appreciated
Sean M.
Sean M.
These will be my next tire I have the sti mud trax and I have been happy with him http://www.rockymountainatvmc.com/p/43/81/165/723/-/-/796623/STI-Black-Diamond-XTR-Radial-ATV-Tire-27x11-14?ref=gmc
Go with the ITP Bajacross which is an 8 ply tire. Good all terrain tire and will last. Look it up and read the reviews and info on it. Only up to size 27 I think maybe 28 at the most. Very good tire though if you are looking for thickness and all terrain.
Guest Lenny
I run Mickey Thompson Baja Claws, 31x10.5-15s. I like the tire but they arn't wearing well. For the little mileage they get, they are still lasting a long time. The side walls are thin and I have patched them a few times because of side punctures. For sand dunes, I'll run 5psi in the fronts and six on the rear left and 7.5 on the rear right. They all bulge out the side at the ground the same at these pressures. The rear right is a bit heavier. For the trails I like to run 2 to 3 psi more per tire. Softer tires does soften the ride a lot.
Thanks a lot guys! I work crazy ours as you can tell, so I really dont get to have a lot of me/buggy time. I'll start looking into these tires. Also, do y'all have any suggestions on fenders, because like I said earlier I really need them for the dog pear and thorns we go through during a guided hunt.
I really do appreciate all the help
Sean M
P.S. ive been looking for a roof rack for my buggy. I'm a pretty good welder but I've seen picture of what looks like a pre made rack for the trooper. Im an automation tech trying to get my company off the ground and with 65 employees it's really hard to find time to bend pipe. As I've said before, any suggestions are greatly appreciated.
    • By Duncan
      I got a utv from lowes it has one tire in the back that is the same size as the front tires so it has 3, 26-9-14 and 1 26-11-24. i want to change the rear tire to the same one as the other.So instead of buying a new rim will a 26-11-24 tire fit on a 26-9-14 rim.
    • By Greg Kilgore
    • By BernieG
    • By Jhud
      In the market for side by side. Narrowed it down between the pioneer 1000 or defender Hd9. Looking for pros and cons of both. Any info would be helpful in my selection process. Noise, speed, reliability, ride, all of it.
    • By Stan Morton
      My 2018 XG-850-SL starter died yesterday. The old part number from Kubota is E7153-11732 which has been superceed by part # EG881-63010. I am looking for an aftermarket starter because the Kubota retail price for the starter starts at $550 and upwards toward $850.  If anyone has gone down this road before and has found an aftermarket starter ~ please share with me. We own a ranch and this thing is used every single day and is sorely missed when it is down for maintenance.  Kind Regards, ~ Stan
