Hey guys! Question for you...Does all the years that they made troopers need upgraded rears ? Or is there a year when they started doing them right ? Mine is a 09 model.
Thanks and does anyone know what timing belt to use ?
How about a Thermostat ?
I have an 09 and it had what joyner called the upgrade,no shims to correct the play just different bolts. I would do the lenny upgrade if i were you. Cant help with the belt or thermostat.
Thanks I will look up the Lenny Upgrde..Thanks for the Help!
Anyone with a belt or therm number please let me know.My auto suppliers are not very friendly.........To look for things..There counter people....
Call Casey at JMC for the thermostat and timing belt. He should have both in stock. I don't believe either of these have been matched up with any OEM parts so you won't be able to locate at a parts store. The drive belt you can definitely get as it is a Gates belt and has a part number on it. Casey's number is 480-545-1693.
    • By Joe Breaux
    • By ned
      I have a Kubota RTV -X900 that I recently got from someone that is in good condition.  I'm trying to determine what year it is all to no avail.  I have the 16 digit product identification number and have gone on line to multiple sites with no luck.  The number is A5KB2FDBCFG024444 .  I'd appreciate it if someone could give me an idea where to look this number up and get the year on this unit.  Thanks in advance.
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By GaryC
