I have a very very good used clutch plate and throw-out bearing for $30 plus shipping. Wasn't having any problems with them but replaced them when I had the trans out for some work.
rocmoc n AZ/Mexico
Thanks I will let you know. I ordered the clutch kit from Jose and waiting for it. ....My clutch and flywheel is like new but the pressure plate is shot only one hot spot but it is warped bad. Seems like the bearing had dirt in it. We sprayed the hell out of it with PB Blaster while spining it and it doesnt seem ruff now but you know how that is..Going to spray grease in it and see if we can get it in it..
joynerperformanceparts
We have been asked to make a super heavy duty kelver clutch.We have talked to my clutch guy. And we have increase the pressuer plate from our stock keliver 30% more pressure to 50% more. A new disc with more heaft to it.This is for the guys with big H/P.The stock plate we offer is great for guys with big tires and mid increase in power.Check silverbulletmotorsports for bearing he may be able to find one.If bearing was ruff i would try to find new one.They our hard to find sometimes.
Rick
      Have a bed decal that has never been right.  Contacted Coleman Powersports and they have no solution.  Anyone know of a place where I could get a replacement decal or complete decal or graphics kit?
    • By John M in Louisiana
      Quick question about replacing the plug.  One of the prongs pulled out, so I'm thinking it will be an easy fix to connect the old cord with a new plug but I'm unsure about the specs.  15amp 125v?  Is it more complicated than that?  I do plan to buy a plug that's water tight.
      Thanks in advance!
    • By Woody77
      UTV MASSIMOREPLACED STATOR WANT start replaced rectifier still want start stator ohms out 5 ohms each leg what could be wrong at this point
