Having trouble sorting out this massimo utv
By William P
After a short while of engine running the temp light comes on and the water in the radiator water is boiling., water level is ok pryer to starting engine. This is consistent. Coleman 400 bout 3yrs old
By lmarkie
Any thoughts?
By sxr951
parts for massimo, hisun,etc in florida? where can i get parts for the massimo 700.. like bolts and console i didnt see any bolts on amazon to go with cylinders and any thing when rebuilding a 700 engine
By Ronald
Check engine light comes on after engine runs continuously for 5 minutes or so. I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so? What ya think?
By sxr951
2015 massimo 700.. need cylinder bolt! it some special cut from factory,, its a 125 thread but its like between 8 and 10 mm dont know where to find any ideas? thx
